« 1 ... 153 154 155 (156) 157 158 159 »
Re: Blender 2.6x : actus, tests, feedback...
Post(s): 6567
mcBlyver a écrit:
Le premier qui me dit que c'est déjà possible avec les Boolean et prié de préciser comment on rempli les trous !
(voir l'exemple dans la doc justement à ce sujet)
Il suffit d'inverser les normales des parties internes du mesh.
Contribution le : 10/10/2013 14:22
Post(s): 4021
D'accord, merci, je me tais.
Contribution le : 11/10/2013 07:05
Post(s): 4081
mcBlyver tu sort ! Non mais y'en a marre à la fin de tous ces râleurs !
Non mais c'est vrai qu'en modificateur ça me serait pratique, la je ne l'utiliserai pas cet outil. Il Faudrait faire une copie du mesh original avant, et si on se goure on perd tout, faut recommencer du mesh non coupé en 2 !
Vas y zeauro j'attends ton clash de pieds ferme...
A part ça, les notes de ce week-end !
Hi all,
Here are the notes from today's meeting in irc.freenode.net #blendercoders
1) 2.69 Release Candidate status
- Campbell Barton will gather fixes that would go to the RC branch. He'll propose this tomorrow on this mailing list.
- Tuesday (possibly) we then call for another RC Ahoy, for a second release candidate.
- Splash for RC2 should be updated too. Campbell proposes to find a way to handle it by code (not committing pngs each time).
2) Next release - plans for 2.70
- A refresh or changes in UI startup defaults will be handled during the next weeks. Final proposal is not expected until week after Blender Conference. (Which is in 2 weeks already).
- Because of the upcoming conference, we propose to not move to "BCon2" (which is "release targets defined") before November 3. Might even be later.
- We also need time to check with the Google Summer of Code students which branches can be migrated over to trunk.
- Sergey Sharybin: his "threaded update" branch is almost ready for trunk!
- Howard Trickey mentions his student (Sketch Mesh) also started a review with him for inclusion in trunk.
- We also will be able to tackle compatibility issues for 2.70 (like texface, nodes, ...). That might mean that files saved in 2.7x versions won't read fully compatible in 2.6x versions - with a warning on load.
We will first collect all compatibility issues here in wiki for further review:
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Compatibility_Breaking
- Meeting ended with discussion about the menu option "reset to default value" in the UI, which seems to have issues still - mostly because it's not well defined what the default is - or where a default is being defined. Brecht and Campbell will work together on finding a good solution for it.
Laters,
-Ton-
Ça parle compatibilité ce week-end.
Contribution le : 13/10/2013 17:34
Post(s): 6567
Ce n'est pas parce que je dis qu'on peut utiliser les booléens que je suis contre l'idée d'un modifier bisect.
On peut aussi utiliser un knife, faire une sélection, la supprimer et faire des grid fill pour faire la même chose en edit mode.
Le bisect n'est pas indispensable pour modéliser mais il regroupe 3 opérations en une pour un usage plus spécifique et est plus rapide et pratique.
Ce serait la même chose pour un modifier bisect.
Vivement le mois prochain qu'on ait un vrai clash sur les 2.70.
Contribution le : 13/10/2013 20:24
Post(s): 791
Contribution le : 15/10/2013 06:09
Dev Blender | http://mont29.wordpress.com/
Post(s): 4081
Et des notes en voici en voilà !
Hi all,
Here's a couple of notes from today's meeting in irc.freenode.net #blendercoders
1) Blender 2.69 release candidates
- Bug reports keep coming in! All showstoppers were tackled though.
- Meeting proposes to call for official 2.69 release build tomorrow. Last fixes from trunk were merged to release branch already. We would like everyone (and Campbell Barton, who's in USA atm) to check if it's OK!
2) projects for 2.70
- No news compared to last week's list of possible projects for 2.70.
- Ton Roosendaal mentions he had a meeting with Brecht van Lommel about all UI work the coming period. Brecht agreed on accepting the responsibility to coordinate/lead this, also to look into expanding the UI 'owner' team with more developers and designers.
3) Git and Phabricator migration
- We're finally moving to git! Here's the plan:
http://wiki.blender.org/index.php/Dev:Ref/Migration_to_Git_Phabricator
- There's also work being done to swap the www.blender.org website with the new staging.blender.org one. Even though the latter is not finished, switching it might give a bit more incentives and energy to then do it after all!
Thanks,
-Ton-
La 2.69 arrive, arrive... mais n'est toujours pas la .
Oui la ça va clashé. Au fait faudrait peut-être crée un topic pour les 2.7x non ?
Contribution le : 20/10/2013 19:49
Post(s): 356
En attendant, pour l'UI, on a quelques rapport de développeurs à se mettre sous la dent :
- Ack-err (pour son Google Summer of Code, principalement la vue 3D) :
http://wiki.blender.org/index.php/User:Ack-err/GSoC_2013/Final_Report
-Brecht : http://wiki.blender.org/index.php/User:Brecht/UI
+ Une proposal en cours : https://docs.google.com/document/d/1ScPMbHv8WRCU2znB7IU2l-W9hH-NLs5weQKLkjqmgpA/edit?pli=1#
Contribution le : 20/10/2013 21:29
Post(s): 723
L'équivalent du viewer du compositing pour Cycles plus plein de fonctions en plus :) : http://adaptivesamples.com/node-wrangler/
J'ai essayé (à tester avec une version > 2.68.2), ça fonctionne super et ça permet de mieux comprendre l'effet de certains nodes.
Contribution le : 20/10/2013 22:00
De Bayonne
Post(s): 1289
Il n'y a pas à dire, à la lecture de ces trois liens on se rend compte que la réflexion autour de l'évolution de l'interface est beaucoup plus poussée et réaliste que ce qu'a proposé Andrew Price...
Contribution le : 21/10/2013 13:43
www.tynaud.com
Post(s): 723
Contribution le : 21/10/2013 20:59
The Blender Clan 'tchat Blender Tribu, un nouveau forum 5 585 26/06 11:18:05
Questions & Réponses Machine distante puissante 1 74 25/06 13:33:05
Questions & Réponses Lattice cylindrique 2 62 25/06 12:33:08
[WIP] et travaux terminés Participation au concours Spark Avec Blender 2 127 25/06 11:51:13
ArnaudT
Questions & Réponses [résolu] Transition couleur 7 324 23/06 23:13:47
Questions & Réponses Image étiré sur un objet 3 149 23/06 22:50:24
Questions & Réponses [non résolu] Mes UDIM ne se chargent pas automatiquement 2 113 23/06 18:00:47
Voltrum
Questions & Réponses Je n'arrive pas à rendre mon animation, je n'obtiens que des images noires    [1][2] 16 56323 23/06 17:48:25
Questions & Réponses booleen: Faire une différence entre deux objet 4 252 21/06 00:08:50
BlendProblem
Hors Sujet !! les tutos de Moonboots    [1][2][3]...[29] 284 40292 18/06 09:13:32
Questions & Réponses Panneau disparu en passant de 3.0 à 3.2 2 200 18/06 08:53:13
The Blender Clan 'tchat Avenir du blender clan    [1][2][3]...[42] 415 58867 15/06 19:35:29
Teto45
Questions & Réponses [résolu] effet de fumée: mon cube "domain" apparaît lors du render 2 289 14/06 09:42:07
PounchPounch
[WIP] et travaux terminés [WIP] Les tests de mon gros projet (merci pour vos conseils)    [1][2][3][4] 33 51559 13/06 13:37:51
The Blender Clan 'tchat Leurre ?    [1][2][3] 22 1296 08/06 02:04:39
Moteur de jeu GameBlender et alternatives [non résolu] Cs (vaisseau)    [1][2][3]...[57] 567 185789 07/06 20:14:37
Questions & Réponses [non résolu] Cycle rendre une vitre de manière visible 0 180 06/06 10:33:25
The Blender Clan 'tchat VSE !!! 2 318 05/06 02:35:33
The Blender Clan 'tchat Inscription BlenderClan 6 1181 04/06 09:50:41
The Blender Clan 'tchat Les muets 0 230 03/06 23:04:31
253 utilisateur(s) en ligne (dont 79 sur Forums)
Invité(s): 252
DaltonDion, plus...
KarissaC65 28/6/2022
JinaRosenb 28/6/2022
SheilaErne 28/6/2022
GayGoldsmi 28/6/2022
JoanH4248 28/6/2022
RodneyMarl 28/6/2022
ClaudeKees 28/6/2022
TiaSouthwi 28/6/2022
LaraeGutie 28/6/2022
ElkeHuggin 28/6/2022
Jui 9
plus 238 plus d'élément(s)
