« 1 ... 4 5 6 (7) 8 9 10 ... 74 »
Re: Blender 2.7x : actus, tests, feedback...
Post(s): 566
Cette semaine dans le compte-rendu :
Hi all,
Here's the notes from today's meeting in #blendercoders, irc.freenode.net.
1) Blender 2.70 projects
- Current schedule (not changed since last week)
http://wiki.blender.org/index.php/Dev:Doc/Projects
- Tabs! Jonathan Williamson summarised status of tabs. After lots of discussion throughout the week seems many people can agree on a couple things:
1) tabs should be workflow based when possible.
2) user should switch tabs minimally.
3) panels within tabs should fit nicely on a 1080p monitor.
He also updated tab doc, showing the larger picture for other UI work too:
http://wiki.blender.org/index.php/Dev:Ref/Proposals/UI/Tab-Interface
One of the most complex ones, Editmode tabs review:
https://developer.blender.org/T37568
Meeting agrees with moving on adding tabs (following current design proposal) in 2.70.
- Tamito Kajiyama had positive feedback from core Freestyle users about the new Python API for Freestyle - which will break older scripts. Goes to 'git master' this week.
- Jonathan Williamson's keymap project (a new choice next to maya/max etc):
Question: is this acceptable to add in BCon3 still? Might be better 2.71? Final answer next week.
https://developer.blender.org/T37420
https://docs.google.com/document/d/1cXzHJgkIPEXIkXBGSJmI29_AVY_xliI9-TpKmLKxv_8/edit#heading=h.mcrqhsmmkmba
2) Other projects
- Sebastian Koenig shows error in mask rasterizing when mask-curves overlap. Anyone around to solve this well?
http://cl.ly/image/1g2f2q0v0m3f
- Tamito works on Freestyle textured strokes:
-Ton-
En bref, pas mal de tabs, un peu de Freestyle et pas mal de trucs.
Source :
http://lists.blender.org/pipermail/bf-committers/2014-January/042712.html
Contribution le : 26/01/2014 21:02
Post(s): 566
Histoire de contnuer sur la société Microvellum (ceux qui ont crée un fork de Blender dédié à l'architecture), ils font maintenant parti des sponsors de niveau "diamant" (le plus haut possible) rejoignant ainsi Blender Cookie et Convergen.
Je leur souhaite une bonne réussite professionnelle vis à vis de ce projet (et des autres non impliquant Blender).
Contribution le : 01/02/2014 11:33
Post(s): 566
Compte-rendu de la semaine :
Hi all,
Here is a summary of today's meeting in irc.freenode.net #blendercoders.
1) Blender 2.70 progress
- Planning is still the same! In two weeks we'll make release candidates.
- Release log in progress:
http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.70
GE LOD needs a doc still.
- Priority for everyone who works for Dev Fund or Blender Institute: bug tracker!
- Work on tabs for toolbar is in progress, it's being reviewed using developer.b.o site reports. Check for example:
https://developer.blender.org/D275 (Object mode)
- Proposal to cleanup panels in Image Editor:
https://developer.blender.org/T38371
- Campbell Barton would like some usability testing on a patch: Gesture based multi-button dragging/editing. https://developer.blender.org/D270
- Sergey Sharybin tested an update to latest Carve library. It supports ngons and edge data interpolation (like uv maps, crease) and will solve several bugs.
Almost finished patch: https://developer.blender.org/D274
Might go in 2.70 yes.
- Tamito Kajiyama: Freestyle API revisions are in git master; work on the Freestyle section of the 2.70 release log is in progress. Special thanks to Folkert de Vries finding and solving bugs.
2) Other projects
- Sergey: at some point next week developer.blender.org could be unavailable due to maintaince.
- Ton Roosendaal: we had a meeting here to map out topics related to the Gooseberry pipeline. Full report coming soon. No big conclusions, just a lot of work ahead :)
Laters,
-Ton-
Source :
http://lists.blender.org/pipermail/bf-committers/2014-February/042744.html
Contribution le : 02/02/2014 19:45
Post(s): 6567
Genscher vient de mettre ce patch pour les cloth dans le master.
http://youtu.be/-Y_bC0gjoM0
Petit test rapide.
http://www.pasteall.org/pic/show.php?id=66392
Ca a l'air de bien fonctionner.
Contribution le : 06/02/2014 21:01
Post(s): 116
J'aimerais vous poser une question s'il vous plaît.
Es ce que quelqu'un sais si les versions 2.7X proposerons d'utiliser les carte graphique AMD?
Contribution le : 09/02/2014 15:50
Post(s): 410
Tu veut dire au niveau du render GPU ?
Contribution le : 09/02/2014 18:17
Art Station | Blender Lounge
Post(s): 116
Oui, je parlais bien du rendu via le GPU
Contribution le : 09/02/2014 18:19
Post(s): 566
Compte rendu de la semaine :
Hi all,
Here are the notes from today's meeting in irc.freenode.net #blendercoders.
1) Work on upcoming 2.70 release
- Planning for release didn't change:
- Image Editor panels are being reshuffled now:
- Crucial bugs to be done are now listed in a special page:
https://developer.blender.org/project/view/35/
- Showstopper bug is for Windows with non-Ascii character file paths (like Japanese).
https://developer.blender.org/T35176
Campbell Barton and Tamito Kajiyama will check on it.
- Note! Python scripters who added toolbar buttons should check and/or update scripts, because of news tabs there. Connect Campbell if you need help.
source : http://lists.blender.org/pipermail/bf-committers/2014-February/042768.html
- Sketchfab will submit an add-on to be included in release, using the 'commercial services' deal we've reviewed and accepted last August. It still needs to be reviewed though.
2) Other projects
- Ton Roosendaal wrote a report of the developer meeting in Blender Institute, to map out issues for the next film project:
http://gooseberry.blender.org/developer-meeting-pipeline-and-tools/
- Lukas Toenne started to work on a cleanup compositor code, will be online this week.
- After the meeting, there was a discussion on the status of NPR render in Blender, and the 'BEER' project from Bong Wee Kwong.
http://wiki.blender.org/index.php/User:LightBWK
A new mailing list has been added to discuss work on Blender's NPR render future:
http://lists.blender.org/mailman/listinfo/bf-blender-npr
Thanks,
-Ton-
En résumé on a des corrections de bugs, une mise en garde sur python et les tabs, un redisign de l'interface sur l'édition d'images et surtout un avancement dans le render interne de Blender et des NPR (Non photorealistic render).
Post(s): 6567
C'est vrai que ce meeting est plutôt relatif à l'organisation et à des projets qu'à du concret.
Pour ça, il vaut mieux regarder le dernier sneak peak.
http://youtu.be/MR1bpKHrvMs
@ CDCST, à ma connaissance, il n'y a pas eu d'annonce dans ce sens. Mais il ne faut pas confondre Blender et Cycles.
On peut toujours faire sa scène avec Blender et du rendu GPU avec un autre moteur de rendu les supportant.
Contribution le : 10/02/2014 10:36
Post(s): 433
Youuhoudibadadouuu !!
C'est noël avec 10 mois d'avance (ou deux de retard) ! On peut désormais baker un peu tout et n'importe quoi avec Cycles, grâce à l'excellent travail de Dalai Felinto !!
La liste de passes bakable est impressionnante, avec support du margin est même une petite GUI très sympa dispo dans le panel des matériaux (il faut activer l'add-on CbakeGUI).
Plus d'infos ici.
Il y a des builds dispo sur graphicall pour Linux, Windows et Mac.
Bon je retourne faire joujou avec tout ça, jusqu'ici ça fonctionne du feu de dieu !
Peace !
edit : et le lien blenderartist pour les feedbacks
Contribution le : 14/02/2014 13:25
"Qu'y puis-je si que dalle n'y comprends-je ?" (Ptiluc)
[WIP] et travaux terminés Pagani Zonda Barchetta 4 109 Aujourd'hui 12:31:43
Questions & Réponses chemins suivant une déformation de surface 6 101 Aujourd'hui 12:26:50
The Blender Clan 'tchat W10 pour le prix d'une cacahuète    [1][2] 10 134 Aujourd'hui 11:14:45
Questions & Réponses Vitesse d'une vidéo 4 72 Hier 19:59:42
Questions & Réponses Texture et courbe de Bézier 3 47 Hier 19:50:15
Questions & Réponses Armature sans parenté? 1 41 Hier 19:38:25
[WIP] et travaux terminés [WIP] La pince à linge 5 78 Hier 13:34:08
The Blender Clan 'tchat Avenir du blender clan    [1][2][3]...[41] 405 48772 17/01 20:40:59
Questions & Réponses texture eyes avec empty 1 51 17/01 13:17:33
[WIP] et travaux terminés [WIP] La gabarre '' Le Gros Ventre''    [1][2][3]...[12] 110 22017 16/01 19:03:45
The Blender Clan 'tchat Progression dans Blender et la 3D    [1][2] 11 477 16/01 17:37:45
Questions & Réponses [terminé] Modificateur Mirror sur un Vertex Group 2 85 16/01 15:55:36
Questions & Réponses Ma caméra me saoule... 5 216 15/01 20:33:23
Hors Sujet !! Appareil Photo Compact, qualité, zoom...    [1][2] 19 419 14/01 14:45:17
Hors Sujet !! Tuto Astraonaute low-poly + rigify en 25mm 1 128 14/01 11:50:21
Questions & Réponses [résolu] Comportement du parentage et du Weight Paint bizarres    [1][2] 14 78295 10/01 15:17:23
Hors Sujet !! BONNE ANNEE LE BLENDER CLAN    [1][2] 10 385 10/01 13:34:18
Questions & Réponses Limit location constraint-Affect transforms 4 179 09/01 14:33:38
Questions & Réponses Mon objet suit la courbe à 12 km...    [1][2] 10 551 08/01 01:37:51
Questions & Réponses Mauvais parentage en automatic weights    [1][2] 18 559 07/01 18:55:45
225 utilisateur(s) en ligne (dont 90 sur Forums)
Membre(s): 5
Invité(s): 220
JuliannPad, PansyChapl, LeonorEbne, JudiTennys, ShirleyDug, plus...
BlondellGa 2/1/2022
EileenTomk 2/1/2022
RamonaDahl 2/1/2022
SashaBeals 2/1/2022
TroyLightn 2/1/2022
PhillippBu 2/1/2022
LesterHida 2/1/2022
PansyHolm 2/1/2022
YukikoMitt 2/1/2022
Randall318 2/1/2022
Fev 19
Anniversaire de APPGirault123
plus 244 plus d'élément(s)
