(1) 2 3 4 »
Save/load sur fichiers différents
De Thionville (près de metz)
Post(s): 402
Bonsoir
Pour sauvegarder les parties, j'utilise ce script que j'ai trouvé sur Internet :
import bge
scene = bge.logic.getCurrentScene()
objects = scene.objects
#set global varialbles instances
if not "properties" in bge.logic.globalDict:
bge.logic.globalDict["properties"] ={}
if not "position" in bge.logic.globalDict:
bge.logic.globalDict["position"] ={}
if not "orientation" in bge.logic.globalDict:
bge.logic.globalDict["orientation"] ={}
def save():
controller = bge.logic.getCurrentController()
owner = controller.owner
#sets local properties
for object in objects:
if type(object)==bge.types.KX_GameObject:
bge.logic.globalDict["position"][str(object)] = list(object.worldPosition)
bge.logic.globalDict["orientation"][str(object)] = list(object.worldOrientation[0]),list(object.worldOrientation[1]),list(object.worldOrientation[2])
for property in object.getPropertyNames():
if len(object.getPropertyNames()) > 0:
bge.logic.globalDict["properties"][str(object)] = {}
bge.logic.globalDict["properties"][str(object)][property] = object[property]
#sets position and orientation
bge.logic.saveGlobalDict()
print("Saved File")
endgame = [sens for sens in controller.sensors if type(sens) == bge.types.SCA_KeyboardSensor]
if len(endgame)>0:
if endgame[0].key == bge.events.ESCKEY:
bge.logic.endGame()
def load():
#imports properties from the save actuator
bge.logic.loadGlobalDict()
#sets the properties from the globalDict imports
for ob in bge.logic.globalDict["position"].keys():
if ob in objects:
object = objects[ob]
#sets the orientations from the globalDict imports
object.worldPosition = tuple(bge.logic.globalDict["position"][ob])
object.worldOrientation = tuple(bge.logic.globalDict["orientation"][ob])
if ob in bge.logic.globalDict["properties"]:
for property in bge.logic.globalDict["properties"][ob].keys():
object[property] = bge.logic.globalDict["properties"][ob][property]
print("Loaded File")
Arrive ma question. Ce script enregistre la position d'objets, leur rotation et toutes les propriétés.
Je voudrais l'approfondir en faisant la chose suivante.
Dans un jeu, imaginons 2 niveaux, chacun sur une map, 1.blend et 2.blend.
Une fois le niveau 1 passé, blender charge 2.blend avec la logic-brick load game : 2.blend.
Je voudrais maintenant que le script enregistre le fait que le joueur soit passé sur la map 2.
En relancant le jeu, l'information serai chargée et le jeu reprendrait au fichier 2.blend.
En écrivant ces lignes, une idée me vient à l'esprit. Je pourrais attribuer une propriété correspondant à chaque niveau, une de valeur 1 pour 1.blend et une de valeur 2 pour blend.2. Ok, les propriétés sont enregistrées, mais comment dire à blender de charger tel niveau s'il lit dans le fichier que la prop est égale à 1 ou 2 ?
Des idées ? Bonne soirée à vous
Contribution le : 21/02/2014 19:23
Re: Save/load sur fichiers différents
De Montpellier
Post(s): 1041
Salut! Oui bonne idée pour la propriété niveau:
niveau 1
niveau 2
Enfin c'est du vite fait j'ai pas trop testé mais ça a l'air de marcher.
Par contre la prochaine fois essaie de mettre ton code dans un bloc de code pour avoir l'identation parce que j'ai galéré pour la rétablir
Pour tester: Dans le niveau1: P pour démarrer. Right puis N pour faire augmenter la propriété niveau puis S pour sauvegarder. Puis Escape pour quitter. Puis P pour lancer la partie, puis L pour loader la partie (ça chargera le niveau 2)... Bon c'est pas du très propre mais c'est juste pour le principe...
A+!
Contribution le : 21/02/2014 21:16
Post(s): 402
Je me contenterais de ça, merci beaucoup !
Je sais pas où tu as pécho ce script ahah mais il fait bien son travail.
Bonne soirée
Edit : Pourtant, quand je créé mon blend en copiant le script, la sauvegarde ne s'effectue pas...
Le fichier : http://7uztws87zq.1fichier.com/
Contribution le : 22/02/2014 20:08
De Montpellier
Post(s): 1041
Mais c'est ton script que j'ai utilisé!
Je l'ai juste modifié un tout petit peu vers la fin
Je regarde ton .blend et j'essaie de voir ce qui ne va pas...
En fait dans ton script, il y a 2 fonctions:
1 pour sauvegarder et une pour loader. Ce que j'ai fait, c'est que j'ai dit que si j'appuie sur la touche S, ça fait tourner le 'module' (la fonction) save() du script. Si j'appuie sur L, ça fait tourner le 'module' load() du script.
Mais tu peux très bien faire comme ceci:
Save/Load
La sauvegarde se faisait bien mais le print (saved file) ne s'affichait pas dans la console.... Enfin bon voilà
Contribution le : 22/02/2014 20:29
Post(s): 402
Contribution le : 22/02/2014 20:34
De CH [+]
Post(s): 1558
Ben c'est simplement qu'aucun objet (de type KX_GameObject, bref il n'y a que le cube) de la scène ne contient de property... Si tu en ajoutes une au cube, alors ça marche.
EDIT: parce que sinon, "object.getPropertyNames" rend une liste vide.
Contribution le : 22/02/2014 20:43
Post(s): 402
Non, même en ajoutant une propriété :
http://2k2wkiqv0h.1fichier.com/
Contribution le : 22/02/2014 20:54
De CH [+]
Post(s): 1558
J'm'excuse mais ça affiche bien "Saved file", cette fois. Parles-tu donc d'un autre problème?
Si c'est que le jeu ne s'arrête pas comme tu le penserais, c'est que le senseur est sensible à la touche S, pas ESC...
EDIT: et du coup il suffit de changer la touche dans le senseur pour que ceci marche. Si tu veux le faire proprement et éviter des bugs (jeu pas sauvé), change de touche d'arrêt par défaut dans le panneau Render / ou par Python.
Contribution le : 22/02/2014 21:00
De Montpellier
Post(s): 1041
Look at my edit
Contribution le : 22/02/2014 21:01
De CH [+]
Post(s): 1558
@youle: plus beau, tu mets un seul senseur Keyboard avec All Keys activé, et tu récupères la touche dans le script.
Contribution le : 22/02/2014 21:05
(1) 2 3 4 »
Hors Sujet !! les tutos de Moonboots    [1][2][3]...[24] 239 24836 Hier 21:57:38
Questions & Réponses Solution rendu saccade    [1][2] 14 199 Hier 20:41:12
Elise1002
Questions & Réponses Découper un objet selon un autre 3 79 Hier 18:06:34
mamain83
Questions & Réponses Texture baké devient noir    [1][2] 14 100 Hier 07:58:33
Questions & Réponses Raccourcis clavier qui ne marchent plus v 2.93.4 0 44 26/11 19:16:31
The Blender Clan 'tchat Conseil pour débutante 4 358 25/11 16:24:59
Ksuhma
Moteur de jeu GameBlender et alternatives [WIP] DeadSigns FPS Unity - Version alpha disponible + discord    [1][2][3]...[68] 672 152196 25/11 11:59:06
Questions & Réponses Récupérer la couleur en sortie de shader 8 168 25/11 09:33:29
bibi
Questions & Réponses Peut-on entrer les coordonnées du point visé de la caméra ? 4 139 24/11 19:16:16
Questions & Réponses [résolu] snap fixe sur les cm ou mm 2 108 24/11 17:47:40
mamain83
Questions & Réponses debutant- engrenage en pointe 8 256 24/11 17:30:55
The Blender Clan 'tchat ANNONCE IMPORTANTE : LE BLENDER CLAN REOUVRE !! Etat des lieux sur le présent et le futur :)    [1][2][3] 20 44116 24/11 01:55:17
jor760
Questions & Réponses [non résolu] Fusion 360 - recherche d'un connaisseur 0 99 22/11 18:24:48
The Blender Clan 'tchat [abandonné] Clavier Corsair K55 RGB Pro / Raccourcis clavier    [1][2] 14 447 21/11 19:46:01
Questions & Réponses Paramétrage des Particle System 0 109 21/11 10:05:15
Questions & Réponses Gestion des Hook 4 177 21/11 09:26:17
Questions & Réponses Tissu élastique    [1][2] 14 487 21/11 09:21:27
Questions & Réponses csv>python>blender 8 1251 18/11 18:46:06
Questions & Réponses Editer un nom avec la police 'DroidSans.ttf' en hindi 0 121 18/11 09:55:16
152 utilisateur(s) en ligne (dont 82 sur Forums)
Membre(s): 5
Invité(s): 147
MeredithCa, SophieD14, OllieHargr, NellyOuc81, StaciaCrea, plus...
VeronaI97 28/11/2021
IPEJosie4 28/11/2021
IndiaSneed 28/11/2021
KandySauls 28/11/2021
SterlingQ3 28/11/2021
BellaWan15 28/11/2021
XHIAmie485 28/11/2021
DwayneThig 28/11/2021
MitchellGo 28/11/2021
AntonioAng 28/11/2021
